Multiple JMX enabled applications on the same host
  • isurugiu
    • Apr 2015
    • 13
    I have 3 different Java JMX enabled applications installed on the same machine. Now I have to monitor a lot of stuff for them.
    I have created the JMX interfaces listening on different port numbers.
    My question is how to I apply the template for each JMX interface or should I add the host 3 times under different names with a single JMX interface?
    Best,
    -Iulian
  • BDiE8VNy
    • Apr 2010
    • 680
    Due to lack of ZBXNEXT-735 the most manageable way is by creating one host per JVM.
    When deciding to use multiple JMX host interfaces on the same Zabbix host anyway, then be aware of ZBX-8623.
