Fatal error compiling PHP 7.4 on Sol 10 - ld: fatal: wrong ELF class: ELFCLASS32
  • stuart.salter
    • Feb 2021
    We're configuring with the following options: ./configure \ --disable-xml \ --disable-libxml \ --disable-dom \ --disable-simplexml \ --disable-xmlreader \ --disable-xmlwriter \ --without-pear \ --without-sqlite3 \ --without-pdo-sqlite \ when running 'make' we get the following error:
    ld: fatal: file /usr/local/lib/libiconv.so: wrong ELF class: ELFCLASS32 ld: fatal: file processing errors. No output written to sapi/cli/php *** Error code 1 make: Fatal error: Command failed for target `sapi/cli/php'
    paths are set as follows:
    echo $PATH /opt/csw/bin:/usr/bin:/usr/sbin:/opt/solarisstudio12.3/bin:/usr/local/bin:/app/mysql/usr/local/mysql/bin:/usr/local/bin/gcc:/usr/sbin:/usr/bin:/usr/local/bin:/usr/ccs/bin # echo $LD_LIBRARY_PATH /opt/csw/lib:/usr/local/64/lib:/usr/sfw/lib/sparcv9/:/usr/apache2.2/pcre/lib/:/usr/apache2.2/apr_util/lib/:/usr/apache2.2/apr/lib/ # echo $PKG_CONFIG_PATH /opt/csw/bin:/usr/lib:/usr/local/lib:/usr/include:/usr/local/include:/opt/csw/lib:
    could you help please ? thankyou !
  • tim.mooney
    • Dec 2012
    • 1437
    I think you're posting to the wrong forums. For help compiling PHP, you probably want to post on the PHP forums, not the Zabbix forums.
    You may also want to consider including '-m64' in your CFLAGS before you run configure, but that's something for the PHP forums.
    • stuart.salter
      • Feb 2021
      thanks for the reply !
