Monitoring BACnet protocol
  • joseperes
    • Mar 2019
    • 20
    Can anyone help me, how to monitor BACnet protocol with Zabbix?
    Thanks!
  • whoseyourname
    • Mar 2021
    You'll need a BACnet/N2 gateway which will convert those sensor readings to SNMP. I can't recommend a gateway, yet, since we're in the discovery process of solving the same issue. BACnet gateways connected via RS485 to the control bus.
    • Maxburn
      • Sep 2019
      • 57
      I was just searching for an answer on this sort of thing. I have some devices that seem to "lock up" and stop working on BACnet and would like a zabbix alert of that. I was thinking about an active check with nmap and wondering if anyone put something like that together?
      nmap --script bacnet-info -sU -p 47808 <host>
      Script Output
      47808/udp open bacnet
      | bacnet-discover:
      | Vendor ID: BACnet Stack at SourceForge (260)
      | Vendor Name: BACnet Stack at SourceForge
      | Instance Number: 260001
      | Firmware: 0.8.2
      | Application Software: 1.0
      | Object Name: SimpleServer
      | Model Name: GNU
      | Description: server
      |_ Location: USA
      Requires
      bin
      nmap
      shortport
      stdnse
      string
      unicode
Name:	Nmap BACnet results.png
