Item Creation
  • bitbucket
    • Sep 2020
    • 18
    Item Creation
    When creating an HTTP Agent Item, how/where is the check actually performed? If I have a True/False status value contained in the $.status jsonpath, how is pass/fail determined?
    https://www.zabbix.com/documentation...itemtypes/http
    Check is performed by server/proxy, whichever keeps track of that host.. HTTP item just retrieves data. I guess based on your example here, you pull a json document and then extract a value from it ($.status) with preprocessing. That value is saved as item value. After that you can use the value in triggers.
