Using trigger tags in Trigger Name field
  • enavarro
    • Feb 2021
    Hi all,
    I'm trying to visualise a trigger tag value in the Name string of a problem.
    My Trigger Name is defined as "{HOST.NAME} - DNS server <desired value> not found", where desired value is the value of the trigger tag DNSserver.
    I've tried almost any combination of the {EVENT.TAGS.<tag name>} macro without possitive results.
    Should the
    "{HOST.NAME} - DNS server {EVENT.TAGS.DNSserver} not found"
    or something similar do this task?
    Thank you and best regards,
    Enrique
