Monitoring AWS RDS instance opened port
  • peshta
    • Feb 2021
    Hi all,
    I am fairly new in the whole "cloud monitoring" game. I've been living on premises for over 2 decades, but its time to move on.
    Anyways, can you suggest a solution how to monitor if a port 5432 is opened on my xxxxxxxxxxxxxxxx.us-east-1.rds.amazonaws.com RDS instance ?
  • Zdenek_OMNISENSUIT
    • Nov 2020
    • 55
    Hello.
    You have few possibilities on cloud.
    I have not info your network setup but generaly you need acces to be able check this port.
    You should define your network rules(VPC/GW/ACL/.......) to be able expose this port to your zabbix on-premise installation or use zabbix proxy (vm/container) inside AWS and setup secure connection between you Zabbix server and proxy.
    Then setup network rules inside AWS to be able use this proxy to monitor what you want.
    omnisensuit.com
