Zabbix server with several network cards
  • zabbix_user84
    • Jan 2021
    • 25
    I hope you can give me an answer. Thanks in advance!
    My Zabbix server initially had only one network card, so only one IP. I could access its administration console via HTTP normally. Subsequently I had to install a VPN client on this same server, which had the consequence of adding a second ip.
    I would like to access the Zabbix server via the second IP in the same way as the first one, but this is not possible. Each time I am redirected to my initial IP in my web browser.
  • zabbix_user84
    • Jan 2021
    • 25
    Nobody has an answer ?
    • gofree
      • Dec 2017
      • 400
      This has nothing to with Zabbix in general - apparently you need to configure your web server ( apache. nginx ) to suit your needs.
      • zabbix_user84
        • Jan 2021
        • 25
        Thanks !
