Calculated field based on agent2 and mqtt
  • mario.in.dcstar
    • Feb 2021
    hello
    we get the power from our shelly devices with mqtt and agent 2 but when i want to make a calculated field for the current (power/voltage), than I get an error on the key from mqtt field
    key: "mqtt.get["192.168.0.10:1883","shellies/power/3402/emeter/1/power"]".
    preprocessing: custom multiplier 0.1 (i know, just for this example)
    error: Item with key "mqtt.get["192.168.0.10:1883","shellies/power/3402/emeter/1/power"]" already exists on "System-10.21-PreProd". ====> that is the power measurement
    same concept with rest calls works
    any ideas what i am doing wrong?
    Mario
  • mario.in.dcstar
    • Feb 2021
    Hello cyber,
    I messed up my explanantion, sorry!
    Let me start again:
    1. power meassurement (via mqtt on agent go)
    type: Zabbix agent (active)
    Key: mqtt.get["192.168.0.10:1883","shellies/power/3402/emeter/1/power"]
    Type of info: Numeric (float)
    units: W
    2. current calculation
    type: calculated
    key: 3402current
    formula: last(mqtt.get["192.168.0.10:1883","shellies/power/3402/emeter/1/power"])/220
    ==> last('key ref')/220
    units: A
    ERROR: Invalid parameter "/1/params": incorrect calculated item formula starting from "last(mqtt.get["192.168.0.10:1883","shellies/power/3402/emeter/1/power"])/220".
    The working version with rest calls:
    1. power measurement (rest call)
    type: http agent
    Key: RSSI3405power
    URL: http://192.168.0.167/status
    preprocessing:
    JSONPath: $.body.emeters[1].power
    type: calculated
    Key: RSSI3405current
    Formula: last("RSSI3405power")/last("RSSI3405voltage")
    So if I am correct, the formula should contain the "Key" of the referenced fields ... correct?
    For the rest, that is a text but for mqtt/agent that is a request .
    Mario
      Where is the calculation in your calculated item? All I can see is trying to add a item named "current" with exactly same key as some other item already has... Preprocessing is not a "calculated item"...
      https://www.zabbix.com/documentation...pes/calculated
