with the version OS of zabbix agent I'm able to read the temperature of the processor in a Raspberry Pi4 with out issue launching the below command as user parameter in the zabbix agent configuration
sensors | grep "temp1" | awk '{print $ 2}' | cut -c 2-3
I was wondering if is possibile also on docker, because if I'm executing this command inside of the container I'm receiving this error.
OCI runtime exec failed: exec failed: container_linux.go:344: starting container process caused "exec: "sensors": executable file not found in $PATH": unknown
Or if there is another way to do eventually
Thanks for the support
Miki
Miki
