Installing Zabbix on Fedora 33
  • chase200199
    • Feb 2021
    Dear All:
    I was trying to install Zabbix on a Fedora 33 VM on ESXi.
    The picture is the platform I choosed for the VM:
    After using the command "dnf install zabbix-server-mysql zabbix-web-mysql zabbix-apache-conf zabbix-agent", there was an error:
    Running transaction check
    Transaction check succeeded.
    Running transaction test
    The downloaded packages were saved in cache until the next successful transaction.
    You can remove cached packages by executing 'dnf clean packages'.
    Error: Transaction test error:
    file /etc/httpd/conf.d/zabbix.conf conflicts between attempted installs of zabbix-apache-conf-5.0.3-1.el8.noarch and zabbix-web-1:5.0.7-3.fc33.noarch
    How can I fix the error and installing Zabbix on my Fedora 33 VM successfully?
    Thank you!
