Setting (manual) thresholds for overall disk space, RAM, CPU
  • nilsjman
    • Feb 2021
    First post!
    Zabbix Server 5.0.2
    We're monitoring several (~90) Windows HyperV VMs with mainly Windows Server 2016/2019. With filesystem discovery (vfs.fs.discovery) everything works fine.
    The sizes of the VMs (disk space, RAM, CPU) are defined in a contract. So let's say Client1 has subscribed to a VM with 16GB RAM, 4 CPU cores, 500GB disk space
    Is there a way to set these fixed thresholds (manually) for each VM? So that if for whatever reason the disk space exceeds the size in the contract there is an alarm.
    Alternatively it would be possible to have a calculated item that sums up every discovered vfs.fs.size[#FSNAME,total] item.
    If I do something like:
    Key: vfs.fs.size_calculated
    Formula: last("vfs.fs.size[C:,total]")+last("vfs.fs.size[D:,total]")+last("vfs.fs.size[E:,total]")+last("vfs.fs.size[F:,total]")+last("vfs.fs.size[G:,total]")
    There are errors if e.g. G: doesn't exist.
    Thankful for any input
  • nilsjman
    • Feb 2021
    Or is there a way to get the values which can be seen with e.g. Diskpart -> list disk?
    • nilsjman
      • Feb 2021
      Okay I guess that'll work but how do I get a sum of all discovered FS in the first place or the whole size of the VHDX?
        • 4993
        Originally posted by nilsjman
        First post! ​
        Use host macros. You can create trigger with template and still use macros from host level in it.
