JMX Multiple Keys
  • piti87
    • Jun 2020
    • 23
    JMX Multiple Keys
    Hello
    I try to fetch JMX Values. For always one speratly it works.
    Key: jmx["java.lang:type=Runtime",VmName]
    How can I concat this three fields in one combined Zabbix-Key?
    jmx["java.lang:type=Runtime",VmVendor] + jmx["java.lang:type=Runtime",VmName] + jmx["java.lang:type=Runtime",VmVersion]
    so the desired Result is:
    AdoptOpenJDK OpenJDK 64-Bit Server VM 13.0.2+8
    Thanks and Regards
    *** Zabbix 4.4.5 ***
    • 4985
    This can be done only by using somekind of discovery mechanism.
