How to interpret the measure on CPU load and CPU utilization
  • sontran
    • Feb 2021
    Dear All,
    I really wonder whether my measures as in the attachments are critical or not. From the CPU utilization, I can see that my server is still have room for doing more (min idle time is still 54%). From the CPU load, as I understand the server has 2 cores, so the maximum value of the vertical axis should be 2 but not 0.6 (as shown on the chart). Only in this case the 2 charts are coherent, CPU occupation is about 46% at max.
    In other words, according to the above values if the server has some performance problem, CPU bottle-neck is not a real reason, isn,t it?
    Many thanks in advance for your guide
    Best regardsClick image for larger version
