VMware failed logins triggers
  • Mangirdas
    • Nov 2019
    I am trying to configure triggers fo failed logins and also for "good" logins, but the problem with triggers are that I can't get right value from Item, expression is simple:
    {vcenter:vmware.eventlog[{$VMWARE.URL},skip].regexp(Failed)}=1
    but usually I am not getting values with Failed keyword. Any advice?
  • Mangirdas
    • Nov 2019
    Yes, the latest data is showing matches, but it seems that trigger is activating when is necessary, but alert comes in email with wrong data
      Is your "Latest data" showing any possible matches? As long as I understand, this item pulls all of the log, so if something like that is in original data, your trigger should work.
      Is there any preprocessing applied to item?
