Zabbix agent affinity
  • Amiram
    • Feb 2021
    • 68
    Hey,
    I want to limit the Zabbix agent to specific cores list so it will not interfere with other processes.
    Is it possible to set the affinity of the Zabbix agent (without using taskset etc)?
    Amiram
  • Hamardaban
    • May 2019
    • 2714
    The question is more related to the operating system you are using and its administration than to the zabbix system.
    • Amiram
      • Feb 2021
      • 68
      In all of the Operation-System there is a ability to set the affinity of a process (event in windows ).
      How can I open a feature request for that?
      • gofree
        gofree commented
        Hi, guess you have two ways
        first adjust starting scripts to do what you need to do - shouldn't be to difficult I guess ( especially on linux )
        second - go to Zabbix and ask them to do it https://www.zabbix.com/development_services
