Cannot find host interface on for item key "cpvCurrEspSAsIn"
  • Taner
    • Apr 2018
    • 47
    Hello all,
    I am faced with the error:
    I tried to add Check Point firewall template:
    The Zabbix Team has collected all official Zabbix monitoring templates and integrations.
    Firts I configured in the template in all items with:
    Authentication passphrase
    Privacy passphrase
    Security Level - authPriv
    Authentication protocol - MD5
    Privacy Protocol - AES
    But when I try to add the new host to the template I receive the error:
    Cannot find host interface on"New Host" for item key "cpvCurrEspSAsIn"
    Please could you help me?
    Thank you in advance.
    Best Regards.
  • Hernandes Martins
    • Apr 2011
    • 901
    Hi there,
    Look, in this case you need create a snmp interface in configuration host, after add a template with item.
    Regards
    __
    Att.
    Skype: hernandss
    Telegram: @MrHernandes
    Español
    Português
    • Taner
      • Apr 2018
      • 47
      Hi there,
      Regards
      Yes, you are right, when I use SNMP interface and SNMP agent I can attach the template to the host.
      But now I receive this error:
      Cannot connect to "192.168.1.100:161": Timeout (Sub-id not found: (top) -> hrStorageAllocationUnits).
