Import SNMP MIB files to Zabbix Check Point
  • Taner
    • Apr 2018
    • 47
    What is the easiest way to import SNMP MIB files to Zabbix?
    The version of the Zabbix is 4.0.9.
    The Check Point Device is:
    R80.30
    The mib files of the vendor you can find here:
    https://supportcenter.checkpoint.com...tionid=sk90470
    Please could you share with me your experience and your opinion regarding the topic?
    I try to use SNMP V3 between Zabbix v4.0.9 and Check Point R80.30 with Gaia OS.
    I try to use this template:
    checkpoint-vpn-1-3.4
    https://share.zabbix.com/network_dev...oint-vpn-1-3.4
    Thank you in advance.
  • Hernandes Martins
    • Apr 2011
    • 901
    Hi there,
    Try read the documentarion about, is the best way to do.
    http://net-snmp.sourceforge.net/wiki...d_loading_MIBS
    Regards
    __
    Att.
    Skype: hernandss
    Telegram: @MrHernandes
    Español
    Português
    • Taner
      • Apr 2018
      • 47
      Hi there,
      Regards
      Hello Hernandes Martins,
      Please how I can check in 100% which is my SNMP version of net-snmp tools?
      I suspect my In front end lie me that it supports SNMP V3 but in the backend, it only supports V1 and V2?
      • Hernandes Martins
        • Apr 2011
        • 901
        why not support? your installation is by package or source ? do you take a test snmpv3 with snmpwalk ? you have a sucess or not ?
        try watch a simple videos on youtube to use zabbix with snmp.
        Regards
        __
        Att.
        Skype: hernandss
        Español
        Português
        • Taner
          • Apr 2018
          • 47
          Regards
          I can't test snmpwalk I tried:
          Example:
          snmpwalk -v3 -l authPriv -u USERNAME -a MD5 -A PASSWORD -x AES -X PASSWORD GW2_HostName_or_IP_Address OID
          But in real case how it should be implemented in the terminal line?
          I received for Check Point device only:
          Security Level - authPriv
          User Permissions - read-only
          Authentication protocol - MD5
          Privacy Protocol - AES
          Authentication passphrase and Privacy passphrase
          If the Check Point IP address is 192.168.1.100?
          I don't have user name for the Check Point device.
          And I am worried about and this part in the description of the template:
          "You will need the CHECKPOINT-MIB loaded onto the Zabbix server"
          • Taner
            • Apr 2018
            • 47
            Regards
            Thank you for the videos.
            Now I am here:
            net-snmp-config --version
            5.7.2
            net-snmp-config --snmpconfpath
            /etc/snmp:/usr/share/snmp:/usr/lib64/snmp:/root/.snmp:/var/lib/net-snmp
            I put my mib file GaiaTrapsMIB.txt in this directory:
            /usr/share/snmp/mibs
            • Taner
              • Apr 2018
              • 47
              Now I read this:
              But:
              # Access Control
              mibs +GaiaTrapsMIB.txt
              /etc/snmp/snmpd.conf: line 18: Warning: Unknown token: mibs.
              Where I am wrong?
              The OS is CentOS Linux release 7.6.1810 (Core)
              5.7.2
              • Taner
                • Apr 2018
                • 47
                Regards
                Hello, do you have a time to help me with this:
                How I can load MIB file to SNMP Daemon?
