Read-only permissions to hosts and triggers configuration
  • Valinor
    • Sep 2020
    • 20
    I've tried to restrict permission in Zabbix, but ideally, I want some users to be able to see everything like super-admin, but without permission to change it.
    Everything seems to be fine except these lines from documentations: An Admin level user with Read access to a host will not see the host in the configuration section host list; however, the host triggers will be accessible in IT service configuration.
    I was unable to find this IT service configuration to check triggers expression and as I understand there is no way to give access to host configs as read-only?
    Any workarounds or advice?
    Thanks!
  • Hernandes Martins
    • Apr 2011
    • 901
    Hi There
    No, maybe the way, try use zabbix 5.2 Administration>>User Roles.
    Regards
    __
    Att.
    Skype: hernandss
    Telegram: @MrHernandes
    Español
    Português
    • Valinor
      • Sep 2020
      • 20
      Hi There
      Regards
      Version 5.2.3, all boxes for Admin user type are checked, but until I add Read-write permissions to some Host group I cannot see anything in Configuration>Hosts
      • Valinor
        • Sep 2020
        • 20
        Also, with such config, the user is unable to create any maintenance, cause no hosts or host groups are available in the list. Once I change user groups permission to Read-Write it appears in hosts and in the list for maintenance.
        • Valinor
          • Sep 2020
          • 20
          Can anyone advise? Isn't it strange that the user with the read permissions cannot read?
          • Valinor
            • Sep 2020
            • 20
            update, should I create feature request if it is currently not possible?
