UserParameter with variable substitution and $1
  • operaking
    • Sep 2006
    I am attempting to create a UserParameter with variable substitution.
    The command will sum memory for processes matching an expression passed to the UserParameter, for instance;
    process.mem[jboss]
    Within my command I am using the awk variable $1 to reference ps info;
    awk '{a+=$1} END {print a}'
    My full user parameter is;
    UserParameter=process.mem[*],ps -eao "vsize command" | grep $1 | awk '{a+=$1} END {print a}'
    Of course this doesn't work as Zabbix substitues all $1 variables with it's own variables. I want the first $1 to be the Zabbix supplied 'jboss' and the second $1 to be left alone as it is part of the awk awk command.
    Any ideas how to do this?
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    ZABBIX 1.1, 1.1.1 (note space!):
    UserParameter=process.mem[*],ps -eao "vsize command" | grep $1 | awk '{a+=$ 1} END {print a}'
    In ZABBIX 1.1.2 you may use $$ to quote $:
    UserParameter=process.mem[*],ps -eao "vsize command" | grep $1 | awk '{a+=$$1} END {print a}'
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • operaking
      • Sep 2006
      fantastic! Thanks for your great reply
