Going back and forward in time independent of selected interval
  • ErikEngerd
    • Apr 2012
    • 14
    We know from experience that comparing performance of servers only makes sense by comparing performance of the same time period on a given day with that of exactly 7 days before.
    For instance, the customer reports "the system has gotten slower". Then what we usually do is select a time period of for instance 10:00-16:00 and then step back in time over exactly 7 days.
    This was really easy in previous zabbix versions. Some times we want to look at performance on a given day and then select a period of for instance 3 hours and step back and forward one hour at a time.
    In zabbix 5.0 you select a time range, but then clicking on the back arrow time steps back for exactly the period that your are viewing (in this case 6 hours). What I want is to independenly have two periods: one for viewing (e.g. 6 hours) and one for stepping backwards and forwards in time (e.g. 7 weeks).
    Is there a way to do this in zabbix 5.0?
    Cheers
    Erik
