Zabbix 5.0.9 slack integration
  • svalencia
    • Jun 2020
    • 11
    Hello I have a problem with the integration with slack in zabbix 5.0.9, exactly this happens to me:
    When there is a Trigger Event (some problem on monitoring servers), in event log of Zabbix get an error "Slack notification failed: invalid_auth" and uses all 3 tries, but all notifications apears in slack.
    When problem resolved, in event log of Zabbix get an error "Slack notification failed: channel_not_found", messages don`t update in slack.
  • jgarcia
    • Mar 2021
    I have the same problem:
    Can you resolve the problem svalencia?
    • svalencia
      • Jun 2020
      • 11
      jgarcia not yeat
      • mwildam
        • Feb 2021
        • 72
        Just for the sake of compassion. I have the same issue (on zabbix 5.2.4).
        • mwildam
          • Feb 2021
          • 72
          I have "slack_as_user" set to true in the webhook parameters.
          And it does not make any difference if channel is preceeded with # or not.
          However, it looks like other applications have similar problems with Slack integration, look for example here:And this issue has been already in the forum too: https://www.zabbix.com/forum/zabbix-...slack-centos-8
          However, what has been proposed there does not work any more in the same way as things changed in Slack.
          • tuskov
            • Mar 2021
            "invalid_auth" and "channel_not_found" errors fix in progress now in ZBX-18673
