I am working with Zabbix 3.0 LTS. I monitor specific keys (limit and used count) from API (JSON) source throught external check with *.sh script. If I make own script for each key (curl + jq) (merk_cz_exp-hits.sh, merk_cz_exp-limit.sh) and than specify new calculated item for percentual count based on used amount. Everything woks perfect.
calculated item: 100*last(merk_cz_exp-hits.sh)/last(merk_cz_exp-limit.sh) - work perfect
Now I try to change keys for limit and used items to use same script with parameters for jq:
Item1:
type: external check
key: merk.sh["cz","details_limit"]
information type: number (unsigned)
Item2:
key: merk.sh["cz","details_hits"]
Item3:
type: calculated
formula: last(merk.sh["cz","details_hits"])/(merk.sh["cz","details_limit"])
information type: number (float)
Item1 and Item2 work perfect
Item3 report me back "Not supported" (Incorrect function 'last' expression. Check expression part starting from: "details_hits").
When I try modify Item3 to (merk.sh["cz","details_hits"])/(merk.sh["cz","details_limit"]) zabbix report me back "Not supported" (Incorrect function expression: merk.sh["cz","details_hits"])/(merk.sh["cz","details_limit"]))
Can anyone explain me, where I make a mistake.
Item1:
Item2:
Item3:
type: calculated
