Error after deleting binary logs
  • zimuduyo
    • Mar 2021
    Decided to clean up zabbix
    Went into mysql and made use zabbix;
    then
    TRUNCATE TABLE history;
    TRUNCATE TABLE history_str;
    TRUNCATE TABLE history_uint;
    TRUNCATE TABLE history_log;
    Then I manually deleted all the binary logs and ran
    flush logs;
    then did apt-get update and apt-get upgrade
    Database error
    The frontend does not match Zabbix database. Current database version (mandatory/optional): 0/0. Required mandatory version: 3000000. Contact your system administrator.
    I don't know what to do now.
  • zimuduyo
    • Mar 2021
    then.
    flush logs;
    Database error
    I solved the problem myself.
