Zabbix log trigger not work
  • mikeip1205
    • Jun 2015
    I am new for Zabbix and I have setup a Zabbix that can send email when trigger found.
    But my log monitor trigger seems not work, can anyone help?
    Item
    Type:Zabbix agent (active)
    Key: log[/var/log/auth.log,Failed password,,100]
    Type : Log
    Trigger
    Expression: {server:log[/var/log/auth.log,Failed password,,100].nodata(5m)}=0
    The log look like:
    Jun 18 11:58:33 SVN sshd[9830]: Failed password for account from xxxx
    There are no trigger alert while the world "Failed password" found in the log file.
    Thanks,
    Mike
  • mikeip1205
    • Jun 2015
    The problem is solved.
