Discovery with Powershell 2.0 and JSON
  • WebGreg
    • Feb 2021
    • 49
    Hello.
    Can anyone help me how to convert the script to work in Powershell 2.0?
    Ex.
    UserParameter=custom.vfs.dev.discovery,powershell -NoProfile -ExecutionPolicy Bypass -Command "& {[Console]::OutputEncoding = [System.Text.Encoding]::UTF8; $result_json = @{'data' = @(Get-WmiObject win32_PerfFormattedData_PerfDisk_PhysicalDisk | Where-Object {$_.name -ne '_Total'} | ForEach-Object {@{ '{#DEVICENAME}' = $_.Name }})} | ConvertTo-Json; [Console]::WriteLine($result_json);}"
    Problem is with ConvertTo-Json:
    The term 'ConvertTo-Json' is not recognized as the name of a cmdlet
    In this Host I can't update powershell to higher version. But I need to get some information from it.
  • WebGreg
    • Feb 2021
    • 49
    Has this forum ever helped anyone?
    I browse threads and essentially here are unanswered questions, or the author answers himself.
    • dimir
      Zabbix developer
      • Apr 2011
      • 1080
      For sure there are lots of users that got help from others. Your case is very specific it requires knowledge of Powershell 2 this is why perhaps there is no answer yet. I'm not a Powershell user but it looks like it'd be easier to create a ps2 file with the powershell command
      file: C:\powershell\custom-vfs-dev-discovery.ps2:
      and just call it in UserParameter:
      UserParameter=custom.vfs.dev.discovery,powershell -NoProfile -ExecutionPolicy Bypass -File C:\powershell\custom-vfs-dev-discovery.ps2
      Untested code but I hope you got the idea and this helps. :-)
      • Hamardaban
        • May 2019
        • 2714
        PowerShell 2.0 does not contain implementation of the ConvertFrom-Json cmdlet and ConvertTo-Json cmdlet that are in PowerShell 3.0
        • WebGreg
          • Feb 2021
          • 49
          Exactly But somehow the data was collected early - when the powershell 2.0 was the highest version. Maybe it is still possible without a JSON?
          Yes but I'm new here - I asked 7 questions and this is the second one when someone replied :-D I was curious if the community is alive
          I found this: https://stackoverflow.com/questions/...implementation
          I didn't know how to implement it, but with your hint I have to try splitting it into two files - maybe it will work.
          • WebGreg
            • Feb 2021
            • 49
            Originally posted by splitek
            In my opinion simplest way is to output everything in CSV format and use Zabbix preprocessing: "csv to json".
            Looks promising. Thanks, I'll try this too.
