Monitoring multiple Logfiles
  • mwildam
    • Feb 2021
    • 72
    If I have a bunch of logfiles in a folder, what is the best way to monitor them?
    In the log key of active agent checks it seems that placeholders like * are not supported.
    Do I need to create an item for each possible logfile (assuming I always want to watch out for the same keyword(s) in each log)?
  • mfortes
    • Oct 2019
    • 417
    Assuming that all files have the same extension. U can use that, like this example >
    logrt["K:\Impact360\Data\Logs\integrationservice\*.log", ,,,,]
    If any file can be read... this iten will broke... That way, u'll need to create itens with regex
    Michael R. Fortes
    Linkedin: Mike Fortes
    Medium: mromeiro-f
    • mwildam
      • Feb 2021
      • 72
      Thanks for responding!
      As far as I understood, logrt considers all logs belonging together and only the most recent file is read (interpreting the older ones as history). In my case they are created by different batch jobs.
