Trigger to fire when two of three Hosts are failing
  • Felix Schäfer
    • Mar 2021
    Is there an easy way way to create a trigger that fires when a certain number of hosts fail?
    We use Zabbix to perform web checks from multiple hosts over zabbix proxies. That way we can probe a web API from three different sites.
    We want Zabbix to raise an alert, when the web checks on 2 of the 3 hosts fail.
    Currently we run three web check hosts: wch1, wch2 and wch3.
    We create the trigger by connecting the single host triggers with logical and and or.
    ({wch1:web.test.fail[api check].count(#3,0,gt)}>1 and {wch2:web.test.fail[api check].count(#3,0,gt)}>1) or
    ({wch1:web.test.fail[api check].count(#3,0,gt)}>1 and {wch3:web.test.fail[api check].count(#3,0,gt)}>1) or
    ({wch3:web.test.fail[api check].count(#3,0,gt)}>1 and {wch3:web.test.fail[api check].count(#3,0,gt)}>1)
    That way we test if two of the three checks fail it works.
    But this logical construction is getting more complicated the more hosts you want to check.
    It would be great if there would be some way to configure a trigger that fires, if there is a defined subset failing.
    For example define a list of five trigers and fire an alarm if three of the five fail.
    I did not find any elegant solution yet.
    Thanks for your help
    Felix Schäfer
    Zabbix Version: 5.0.8
  • kriZtof
    • Sep 2022
    It's been a while... found anything better than the 'and/or' combinations?
    I'm also interested in such config or feature. Thanks!
    • markfree
      • Apr 2019
      • 875
      *Web monitoring​
      Since you are using Zabbix 5, have you tried Aggregate checks item type?
      I guess the logic would be:
      Create an item that counts your hosts "web.test.fail[api check]" items.
      grpsum["Your Web Scenario Group","web.test.fail[api check]",count,<your TIMEPERIOD>]
      Create a trigger that says: If the count is greater than or equal to (your own value), then trigger an event.
      {your_aggregate_host:grpsum["Your Web Scenario Group","web.test.fail[api check]",count,<TIMEPERIOD>].last()}>=2
      I could not test this scenario, but I think it might work out.
      Would be great to hear your feedback.
