How to monitor juniper ex series
  • vikingo
    • Jun 2015
    Hi there! I am new so I'll try to help when i can , not only request your help,
    But today i am having some trouble
    I 've installed zabbix, can access the web, it is all operational, but I DO NOT figure how to add juniper ex4200 series, i see there are some templates, but do not figure out how to do it...any whitepaper? any doc i can read?
    I really need a step by step guide to this first implementation, no problem in reading , but please I need this very first time a "dummy guide" for my first monitoring
    thanks a lot!"
  • ArtemK
    • May 2013
    • 232
    zabbix have pretty good wiki, start there.
    you will need to:
    • configure snmp on your switches
    • add new hosts to zabbix for your switches
    • add some templates to your hosts (AFAIK, zabbix comes with some SNMP interfaces templates)
    I did recently the same task, added our ex4200 in virtual chassis to monitoring. However it was a little bit tricky to monitor health status, as there are multiple index OIDs, I used external script to perform SNMP LLD
    I also use custom script to discover interfaces, which provides filtering on adminstatus.
    I don't know if there are some dummy guides, probably no, but there were some books about zabbix, check on amazon.
    • vikingo
      • Jun 2015
      Thanks ArtemK
      Hi ArtemK and thanks
      I am learning from the link you provided. I'll try to get some "how to" from amazon, Thanks again
      • gaspro
        • Sep 2015
        same here.
        Did you manage to get the first device under control?
        I did:
        - add the host
        - add the template for EX4200
        - assign the template to the host, it found 380 items +/-
        But....
        I cant see it going.... i dont see any data nor graphs.
        For example, with Zenoss Core, once added the device, it shows all the interface usage graphs which I find really useful.
        Can someone please help ? Is there a noob reference guide on how to add just one device? I need to get started then I think I'll walk on my feets...
        Thank you,
        Carlo.
