Help: Maps and Screen pages are blank
  • high-t
    • Dec 2014
    • 68
    I'm using Zabbix 5.2.5 .
    Ever since upgrading from Zabbix 4.X , both MAPS and SCREENS display blank pages.
    I'm suspecting this could be something with the corresponding DB tables not being updated correctly, but this is just a wild guess.
    See my MAPS screen attached here.
    Help will be highly appreciated!
    Thank you in advance
    Amit.
  • Yugo
    • Mar 2021
    This also happened to me. After upgrading from 5.0.3 to 5.2.5, map page is blank and would not load. Any help will be appreciated
    • dj_c00ler
      • Feb 2021
      Check webserver (Apache/nginx) error logs.
      • high-t
        • Dec 2014
        • 68
        As per dj_c00ler , I did some Apache2 log check.
        Access log file:
        "GET /zabbix/zabbix.php?action=map.view HTTP/1.1" 500 564 "https://myserver.com/zabbix/zabbix.php?action=dashboard.view"
        Error log file:
        PHP Fatal error: Uncaught ArgumentCountError: array_merge() does not accept unknown named parameters in /usr/share/zabbix/include/classes/macros/CMacrosResolver.php:2118\nStack trace:\n#0 /usr/share/zabbix/include/classes/macros/CMacrosResolver.php(2118): array_merge()\n#1 [internal function]: CMacrosResolver->{closure}()\n#2 /usr/share/zabbix/include/classes/macros/CMacrosResolver.php(2119): array_map()\n#3 /usr/share/zabbix/include/classes/macros/CMacrosResolverHelper.php(674): CMacrosResolver->resolveMacrosInMapElements()\n#4 /usr/share/zabbix/include/classes/helpers/CMapHelper.php(103): CMacrosResolverHelper::resolveMacrosInMapElements( )\n#5 /usr/share/zabbix/include/classes/screens/CScreenMap.php(36): CMapHelper::get()\n#6 /usr/share/zabbix/app/views/monitoring.map.view.php(91): CScreenMap->get()\n#7 /usr/share/zabbix/include/classes/mvc/CView.php(122): include('...')\n#8 /usr/share/zabbix/include/classes/core/ZBase.php(618): CView->getOutput()\n#9 /usr/share/zabbix/include/classes/core/ZBase.php(547): ZBase->processResponseFinal()\n#10 /usr/share/zabbix/include/classes/core/ZBase.php(211): ZBase->processRequest()\n#11 /usr/share/zabbix/include/config.inc.php(25): ZBase->run()\n#12 /usr/share/zabbix/zabbix.php(22): require_once('...')\n#13 {main}\n thrown in /usr/share/zabbix/include/classes/macros/CMacrosResolver.php on line 2118, referer: https://myserver.com/zabbix/zabbix.p...dashboard.view
        My server's PHP version is:
        PHP 8.0.3 (cli) (built: Mar 5 2021 07:53:56) ( NTS )
        Copyright (c) The PHP Group
        Zend Engine v4.0.3, Copyright (c) Zend Technologies
        with Zend OPcache v8.0.3, Copyright (c), by Zend Technologies
        I'm not sure if that error actually relates to a PHP problem of something else...
        • Yugo
          • Mar 2021
          I finally got mine to work. Downgrading the PHP version from 8.0.3 to 7.4 did the trick.
          yum module enable php:remi-7.4
          dnf module install php:remi-7.4
          systemctl restart httpd
          • high-t
            • Dec 2014
            • 68
            My distro is Ubuntu, but nevertheless: So, you're saying I should downgrade my PHP version from 8.0.3 to 7.4 ?
            Thanks!
            • Youpy
              • Aug 2018
              I do have the same issue for at least 2 months with the map
              php 8.0.6
              composer 2.0.13
              Is there a solution with php 8 ?
              [Sat May 15 17:49:55.726553 2021] [php:error] [pid 73535] [client 10.0.2.244:34910] PHP Fatal error: Uncaught ArgumentCountError: array_merge() does not accept unknown named parameters in /usr/share/webapps/zabbix/include/classes/macros/CMacrosResolver.php:2118\nStack trace:\n#0 /usr/share/webapps/zabbix/include/classes/macros/CMacrosResolver.php(2118): array_merge(label: Array, urls: Array)\n#1 [internal function]: CMacrosResolver->{closure}(Array)\n#2 /usr/share/webapps/zabbix/include/classes/macros/CMacrosResolver.php(2119): array_map(Object(Closure), Array)\n#3 /usr/share/webapps/zabbix/include/classes/macros/CMacrosResolverHelper.php(674): CMacrosResolver->resolveMacrosInMapElements(Array, Array)\n#4 /usr/share/webapps/zabbix/include/classes/helpers/CMapHelper.php(103): CMacrosResolverHelper::resolveMacrosInMapElements( Array, Array)\n#5 /usr/share/webapps/zabbix/include/classes/screens/CScreenMap.php(36): CMapHelper::get('3', Array)\n#6 /usr/share/webapps/zabbix/app/views/monitoring.map.view.php(91): CScreenMap->get()\n#7 /usr/share/webapps/zabbix/include/classes/mvc/CView.php(122): include('/usr/share/weba...')\n#8 /usr/share/webapps/zabbix/include/classes/core/ZBase.php(618): CView->getOutput()\n#9 /usr/share/webapps/zabbix/include/classes/core/ZBase.php(547): ZBase->processResponseFinal(Object(CRouter), Object(CControllerMapView))\n#10 /usr/share/webapps/zabbix/include/classes/core/ZBase.php(211): ZBase->processRequest(Object(CRouter))\n#11 /usr/share/webapps/zabbix/include/config.inc.php(25): ZBase->run('default')\n#12 /usr/share/webapps/zabbix/zabbix.php(22): require_once('/usr/share/weba...')\n#13 {main}\n thrown in /usr/share/webapps/zabbix/include/classes/macros/CMacrosResolver.php on line 2118, referer: https://.../zabbix/zabbix.php?action=dashboard.view
              • high-t
                • Dec 2014
                • 68
                php 8.0.6
                composer 2.0.13
                It turns out that Zabbix does not support PHP 8.
                I wasn't aware if that, although this is clearly documented in the requirements pages (link here).
                Once I got that realized, I downgraded PHP to version 7.4 (currently 7.4.19), and everything is now working perfectly, including the screens and maps pages.
                • Youpy
                  • Aug 2018
                  I didn't notice, thank you, this is clear
                  • Sunrise0318
                    • Feb 2017
                    • 24
                    Hello.
                    I update Zabbix 5.2 to 5.4.4 and problem page is blank:
                    Apache log:
                    in access_log:"GET /zabbix/zabbix.php?action=problem.view HTTP/1.1" 500 -
                    In error_log:
                    [Tue Sep 07 21:47:51.322088 2021] [proxy_fcgi:error] [pid 3156203:tid 140250522330880] [client 10.182.7.30:51318] AH01071: Got error 'PHP message: PHP Notice: Trying to access array offset on value of type null in /usr/share/zabbix/include/classes/services/CTabFilterProfile.php on line 181PHP message: PHP Fatal error: Uncaught Error: Unsupported operand types in /usr/share/zabbix/include/classes/services/CTabFilterProfile.php:139\nStack trace:\n#0 [internal function]: CTabFilterProfile->getTabFilter(8)\n#1 /usr/share/zabbix/include/classes/services/CTabFilterProfile.php(156): array_map(Array, Array)\n#2 /usr/share/zabbix/app/controllers/CControllerProblemView.php(107): CTabFilterProfile->getTabsWithDefaults()\n#3 /usr/share/zabbix/include/classes/mvc/CController.php(390): CControllerProblemView->doAction()\n#4 /usr/share/zabbix/include/classes/core/ZBase.php(562): CController->run()\n#5 /usr/share/zabbix/include/classes/core/ZBase.php(214): ZBase->processRequest(Object(CRouter))\n#6 /usr/share/zabbix/include/config.inc.php(25): ZBase->run('default')\n#7 /usr/share/zabbix/zabbix.php(22): require_once('/usr/share/zabb...')\n#8 {main}\n thrown in /usr/share/zabbix/include/classes/services/CTabFilterProfile.php on line 139', referer:
                    I create filter properties in any account but other account is work the problems menu.
                    I use apache 2.4.37 php and php-fpm 7.4.6
                    Mariadb 10.5.9
                    Redhat 8
                    Please help for me.
                    Thank you
