[SOLVED] Zabbix proxy is removed automatically from host
  • ivanni
    • Mar 2015
    • 15
    Hello, Zabbix users,
    I am using Zabbix 2.4.4.
    I have three hosts in the same network:
    Host 1. one host with Zabbix agent which uses active checks to send data to the Zabbix server (which has an internet real address);
    Host 2. one host with Zabbix proxy;
    Host 3. one Synology NAS host which I monitor through SNMP thanks to the proxy of the upper host (number 2).
    I want to make the first host (1) to send its data to the Zabbix proxy first and then the Zabbix proxy to transfer the data to the Zabbix server.
    I don't have any problems with the proxy and it's working fine for monitoring my NAS through SNMP.
    But when I try to configure host 1 to uses the proxy of host 2 (from the frontend: Configuration > Hosts) after a refresh of the page I see that the proxy is removed:
    Firstly I have - my-proxy: host1
    ... and after the refresh I get it like before (and host 1 starts to send to Zabbix server again):
    host1 (and in the configuration I see no proxy).
    Why the proxy is removed automatically? It works for SNMP, but not for the host with the active checks...
    Thank you!
    CASE CLOSED. I resolved the issue - I have forgotteen to add the IP adress of host 2 to the Zabbix agent config file of host 1. Sorry for this post!
  • ethras
    • Jun 2022
    Hello. i'm facing the same issue with Zabbix 6.0.5.
    I add the proxy in the host config with 2 interfaces (SMP and Agent (passive)). It stays there for a while. The proxy gets some data from the host but then after a few minutes the zabbix proxy is again removed from the host configuration.
    Any help ?
