In my Zabbix template, I can monitor the memory usage and it works great... but my issue is when the host server is running SQL, because we allow the SQL service to use all the available memory, I get many alerts because there is more that 90% of the memory that is use on these hosts... So, I would like to disable the memory usage monitor if the SQL service is detected on this host.
I don't want to disable it manually, we have many servers and would like to have it directly in the template.
Any idea ?
Any idea ?
