We are starting to use the VMware SDWAN routers (VeloCloud 520) and I'm seeing inconsistent results when monitoring them with SNMP3. I built a template so the only thing I have to change is the IP address of the router. I have 3 devices, one only gives me intermittent data, one doesn't give me any data and all and the 3rd one works perfectly. I'm using the same template on all 3 and I can do snmpwalk or snmpget from the command line and it seems to work fine. Why is it inconsistent in Zabbix but working ok from the command line on the Zabbix box? For now I'm just looking at ifInOctets.2 and .4 and ifOutOctets.2 and .4. The template has the SNMP v3 creds in it so everything is the same for all 3 devices in the Zabbix setup.
Thanks,
Kerry Miller
Bryan, TX
Thanks,
Kerry Miller
Bryan, TX
