I'm running the appliance 5.2 and collecting via windows agent and SNMP. Roughly 50 hosts total. At this point I can't even log into the web interface since the DB is totally full.
[root@appliance log]# df -h /var/lib/mysql
Filesystem Size Used Avail Use% Mounted on
/dev/sda5 4.5G 4.5G 20K 100% /var/lib/mysql
I've extended the disk in hyper-v so the space is available but when I try to extend it says there is an overlapping partition.
(parted) resizepart
Partition number? 5
Warning: Partition /dev/sda5 is being used. Are you sure you want to continue?
Yes/No? yes
End? [10.7GB]? 15000
Error: Can't have overlapping partitions.
Is there a quick fix for this? It hasn't been collecting very long. I added most of the windows hosts in the last week.
(parted) resizepart
Partition number? 5
Yes/No? yes
