Monitor PowerEdge R720
  • Liran
    • Apr 2015
    • 13
    Hi All,
    Im triyng to monitor PowerEdge R720.
    Unfortunately I could not find template fot that.
    Does anyone have template for the PowerEdge or other template that can work on the PowerEdge?
    Thanks!
    Liran
  • ArtemK
    • May 2013
    • 232
    I created template for PowerEdge T310 using SNMP, not sure if it will work for R720, but you could try
    you need to define value mappings before importing template.
    • Colttt
      • Mar 2009
      • 878
      in attach i've a template for R720 you must activate SNMP and it must be a iDRAV version =>7
      Debian-User
      Sorry for my bad english
      • Liran
        • Apr 2015
        • 13
        Thank you both !
        the template that Artem upload not working for the R720.
        the template that Colttt upload working great!.
        • jamesNJ
          • Jun 2015
          • 103
          Just curious ... I have a pair of R720's in use as an ESX cluster. What OS in on your R720's that this snmp/template works with?
          • Colttt
            • Mar 2009
            • 878
            @jamesNJ: you must run the latest firmware (>=7) and enable SNMP (go to IPMI-WebInterface, Login, iDRAC-Settings --> Network --> Services ->SNMP )
            Debian-User
            • Claudio75Cre
              • Mar 2020
              HI all,
              I am new in the forum and I want expose my problem.
              I had implemented the template of Colttt, but all item are in error (
              No Such Object available on this agent at this OID). moreover I see the mib configuration on template are different from MIB on my file.
              Can you give me more info on how I can resolve this problem?
              in attachement you can find the mib text excract of the server (downoload from dell site )
              The my Zabbix is 4.2 version and the PowerEdge R720 is 8.4
              • Claudio75Cre
                • Mar 2020
                The photo of Item error
