i hope someone can help me:
my original SQL-query looks like (postgreSQL):
so now i would like to use this for ODBC-LLD:
i know something its wrong (get error message: "Value should be a JSON format") can someone help me to do it correct?
thanks in davance!
UPDATE:
that works its in JSON format,
but i need "DATA" in front of it, but it dont work.. any ideas?
select channel.id, channel.name, d_channels.local_channel_id from channel left join d_channels on d_channels.channel_id = channel.id
select '{''"data":[{"{#channelid}":"channel.id"}, "{#channelname}":"channel.name"}, "{#localchannelid}":"d_channels.local_channel_id"}, '']''}' from channel left join d_channels on d_channels.channel_id = channel.id
thanks in davance!
UPDATE:
select json_build_object('#CHANNELID',channel.id,'#CHANNELNAME',channel.id,'#LOCALCHANNELID',d_channels.local_channel_id) from channel left join d_channels on d_channels.channel_id = channel.id;
SELECT '"{data":[', (SELECT json_build_object('#CHANNELID',channel.id,'#CHANNELNAME',channel.id,'#LOCALCHANNELID',d_channels.local_channel_id) FROM channel LEFT JOIN d_channels ON d_channels.channel_id = channel.id),']}';
ERROR: more than one row returned by a subquery used as an expression
