[WEB Monitoring]Get trigger function return value en failed step url
  • nixmind
    • May 2015
    Hi
    I'm configuring web monitoring triggers in zabbix, and I have some information I would like to display, and I can't.
    Typically I'm working on this function
    PHP Code:
    {MY_HOST:web.test.fail[MYScenecarion].last()}<>0
    I would like in the trigger name to display the value returned by the last() function, and my main aim, to display the step/url of my scenario which failed the check.
    In the same way if I use the function this way :
    PHP Code:
    {MY_HOST:web.test.fail[MYScenecarion].last(#n)}<>0
    where n is an integer, I would like to display last n URLs which failed the check.
    I would be pleased if someone can help achieve that. I read the documentation and tested several time without success.
    Thanks for your help.
    Regards.
