Template ICMP ping
  • propusgemini@gmail.com
    • Mar 2018
    • 108
    Template ICMP ping
    Hi!
    if i want ping in a custom interval , i have to fill in the image's part?
    Example i want ping in an interval
    9:00 - 9:05 AM
    how to editing my template?
  • roboris
    • Jan 2021
    • 16
    Can you give more detail about what you want to accomplish? Right now, I'm not sure if you only want to ping every minute from 9:00 to 9:05, and at no other time in the day... or if you want to ping every five minutes all day long, so that if one ping happened at 9:00 the next would happen at approximately 9:05. Please clarify.
    -Brian
      • Mar 2018
      • 108
      Hi Brian,
      i'll try to explain more specific:
      I've created a fake host with IP : 1.2.3.4 for zabbix it's unrecheable.
      i've applied ICMP Ping template and i've configured item in this mode:
      Beucause i want ping that item dall days from 10:50 AM to 10:52 AM
      than i set a trigger
      beaucause i want that after 30 lost ping trigger set up
      At 10:51 (during the item check) nothing happens........ ( my dashboard is empty....)
Name:	dashboard empty.JPG
