"database is not a Zabbix database"
  • akbar415
    • May 2015
    • 119
    I'm trying to migrate the zabbix database from mysql community to mysql enterprise and the follow error occurs
    Table 'zabbix.users' doesn't exist [select userid from users limit 1]
      3571:20150629:174601.263 cannot use database "zabbix": database is not a Zabbix database
    Somebody can help me please?
  • Herwish
    • Mar 2015
    Have you migrated your structure and data? If so - what tool have you used?
    • LenR
      • Sep 2009
      • 1010
      Was there much of a version change between the different mysql versions? Did you run mysql upgrade?
      Are you using innodb file per table?
      • akbar415
        • May 2015
        • 119
        Solved
        The migration is from Mysql community version to enterprise version. I don't know what command was used. I'm not the DBA
        DBA has a tool to do that.
        We figured out what's going on. The mysql tool show a finish status os the migration, but they don't really finished.
        After a few hours work's fine.
        Thanks!
        BTW: In 3 months of use, the zabbix database has 14 G of data (WTF) with 75% infrastrucure being monitored. I see a future with a lot of tunning.
        • LenR
          • Sep 2009
          • 1010
          Run, don't walk, to database partitioning :-)
          Use partitioning instead of housekeeping to manage history and trends retention.
