SSL Cert Expiration Monitoring
  • alexbeau10
    • Mar 2021
    Hello all,
    I a very green when it comes to Zabbix and set up a small instance to test and see if we can use it to consolidate a few different tools we use for monitoring.
    I am working on setting up SSL cert monitoring in Zabbix and found this GitHub HTTPS SSL Cert Check Zabbix from the share.zabbix.com site.
    I have it implemented and working via adding the two user parameters in the zabbix_agentd.conf file. I then have set up my hosts and checks as follows:
    Host Setup Screen
    I am using the local agent to do the check based on agent DNS name string.
    I have then created an item that uses the following key:
    ssl_cert_check_expire[{HOST.DNS}] and using the {HOST.DNS} macro to grab the host name from the host and use that as the first parameter for the check.
    Item Setup Screen
    This works great until I come across an SSL cert that is on a non-standard port. Does anyone know of a way I can pass the non-standard port into the item key? Or a better way to handle checking SSL certs that will handle those on non-standard ports?
    Thanks for any help or insight.
  • Hamardaban
    • May 2019
    • 2713
    at key - ssl_cert_check_expire[{HOST.DNS},{$PORT}]
    and define {$PORT} user macro
