Cisco MIB wrong alerts
  • patrickdenis
    • May 2020
    • 18
    Hi All,
    So I'm having a weird issue, on the 9000 SERIES from Cisco, the ENV MIB is catching some UADP 2.0 TEMP Alert but its shouldnt it is applying the alert of a slot module to the ASIC. Module have a lert set to > 60 from the MIB
    But the UADP should trigger an alert > 120 but instead it is been catch by the MODULE SLOT instead ?
    Is there a way to add a expression or condition that if the NAME UADP is catch to ignore the ALERT ?
    Thank you in advance
