LLD: Filter for disk label
  • ElVengador
    • Apr 2021
    • 29
    First of all: My Situation
    I'm monitoring more than hundret virtual windows server. Some are a little bit older and the new ones are already set up with the actual template regarding drive letters. Now I have the problem that I wat to exclude all drives which are labeled "Pagefile". This is necessary because on the old machines the drive letters are different.
    Thank you!
    Best regards, Michael
  • ElVengador
    • Apr 2021
    • 29
    Originally posted by cyber
    vfs.fs.discovery and vfs.fs.get do not display labels, so it cannot be done on discovery level.
    OK, I understand. Is there any other possibility to resolve this? Because the only way I know is, that I disable the item. But for this I have to do it for every server and not automated.
    • ElVengador
      • Apr 2021
      • 29
      If you have a list of hosts and drives, you could probably disable those over API with a help of some scripting... Might be a bit less manual work and can be repeated.
      Or is it always same drive for those hosts (a la D or F or...) ? You could just have separate template for those hosts, which ignores those drives.
      That is my problem. It's not always the same drive letter. For the newest server there is no problem to make a mass update. But I thought I could filter disks with the label. Because this is the only thing which is always the same. If there is a separate drive for the pagefile it's named "Pagefile".
