LLD net.if.discovery macro regular expression
  • markfree
    • Apr 2019
    • 875
    I'm trying to remove some interfaces from the LLD discovery used in "Linux network interfaces by Zabbix agent" template.
    For that, I'm adding some terms the "{$NET.IF.IFNAME.NOT_MATCHES}" macro.
    My monitored host's "net.if.discovery" key discover the following interfaces.
    # zabbix_agentd -t net.if.discovery
        {"{#IFNAME}":"spu_us_dummy"},
        {"{#IFNAME}":"sit0"},
        {"{#IFNAME}":"imq1"},
        {"{#IFNAME}":"eth7"},
        {"{#IFNAME}":"lo"},
        {"{#IFNAME}":"eth3"},
        {"{#IFNAME}":"br0"},
        {"{#IFNAME}":"bcmsw"},
        {"{#IFNAME}":"ifb1"},
        {"{#IFNAME}":"imq0"},
        {"{#IFNAME}":"eth6"},
        {"{#IFNAME}":"ppp0"},
        {"{#IFNAME}":"eth2"},
        {"{#IFNAME}":"ip6tnl0"},
        {"{#IFNAME}":"ifb0"},
        {"{#IFNAME}":"ip6gre0"},
        {"{#IFNAME}":"eth5"},
        {"{#IFNAME}":"eth1"},
        {"{#IFNAME}":"bcmswlpbk0"},
        {"{#IFNAME}":"dpsta"},
        {"{#IFNAME}":"imq2"},
        {"{#IFNAME}":"spu_ds_dummy"},
        {"{#IFNAME}":"eth4"},
        {"{#IFNAME}":"eth0"}
    I want to ignore interfaces "spu_us_dummy", "spu_ds_dummy", "sit0", "imq0", "imq1", "imq2", "ifb0", "ifb1", "ip6tnl0", "ip6gre0" and "dpsta".
    The default macro uses this regular expression:
    (^Software Loopback Interface|^NULL[0-9.]*$|^[Ll]o[0-9.]*$|^[Ss]ystem$|^Nu[0-9.]*$|^veth[0-9a-z]+$|docker[0-9]+|br-[a-z0-9]{12})
    To ignore those interfaces I thought of adding some terms:
    (^Software Loopback Interface|^NULL[0-9.]*$|^[Ll]o[0-9.]*$|^[Ss]ystem$|^Nu[0-9.]*$|^veth[0-9a-z]+$|docker[0-9]+|br-[a-z0-9]{12}|dpsta|spu_[du]s_dummy|sit0|ifb[0-9]|imq[0-9]|ip6[gre|tnl]0)
    With that, most interfaces are ignored but "ip6tnl0" and "ip6gre0" are still discovered.
    Could anyone help me enhance that macro?
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    The last one should be:
    ip6(gre|tnl)0
    • markfree
      markfree commented
      It now works as expected. Thanks.
