Zabbix Agent auto-registration with certificate based TLS
  • withjigs
    • Apr 2021
    Hi All,
    I have been struggling with this for a few days now. My requirement are:
    1. Certificate based encryption between Zabbix server (5.0 LTS) and agent (5.0).
    2. As we have hundreds of systems, I want to register the agents automatically.
    On the server side:
    • I configured TLS settings (TLSCAFile, TLSCertFile, TLSKeyFile)
    • Created a an Autoregistration Action (Configuration > Action > Autoregistration actions) to add any system with metadata=Linux to appropriate group and link correct templates.
    On agent side:
    • Configured below settings
      • TLSConnect=cert
      • TLSAccept=cert
      • TLSCAFile, TLSCertFile, TLSKeyFile pointing to appropriate files
      • TLSServerCertIssuer, TLSServerCertSubject correct values of issuer and subject of the servers' cert
    > Now, when I restart the agent I see the following error in Zabbix server log:
    autoregistration from "<agent_IP>" denied (host:"agent hostname>" ip:"agent_hostname" port:10050): connection type "TLS with certificate" is not allowed for autoregistration
    > To try a different approach, I decided to create a 'Discovery' rule which scans zabbix_agents and then "add" them using discovery rules (Configuration > Actions > Discovery).
    However, after adding the discovery rule on the server, I started seeing following error on the agent side.
    failed to accept an incoming connection: from <zabbix server ip>: unencrypted connections are not allowed
    To work around that, I had to allow unecrypted connection by making following change in agent configuration "TLSAccept=cert,unencrypted"
    Once the host appears on the server I have to manually enable encryption on the host.
    My questions are:
    1. Is it safe to enable TLSAccept=unencrypted to allow discovery process to find the host?
    2. When we add the "discovered" hosts to group/template etc. using Discovery rule, is it also possible to assign encryption type (cert) and provide issuer/subject automatically?
    Thanks you,
    J
  • cgabriel
    • Jul 2021
    This is such as pain in the ass...I'm not understanding why cert-based autoregistration is not allowed.
    • Rudlafik
      • Nov 2018
      • 168
      Hi, I have same problem. In our environment we have lot of ZBX proxys. On proxy log I read this:
      utoregistration from "<agent_IP>" denied (host:"agent hostname>" ip:"agent_hostname" port:10050): connection type "TLS with PSK" is not allowed for autoregistration
      Resolution was: switch in web management of host:"agent hostname​ item - Monitored by proxy: (no proxy) -> Monitored by proxy: Name Your proxy (Proxy which you set on first position of key: Server=, ServerActive= in ZBX agent config file )​​
