Zabbix sending constant notifications, possible fix similar to .nodata(<time>)
  • hextet
    • Jul 2015
    Zabbix likes to spam notifications which of course is all dependent upon the types of triggers and actions you have set. However for the company I work for, it's imperative that logs are generated quite often as a simple delay in some process can end up costing us a lot of money.
    However sometimes with things like NTP Skew you'll get periodic spikes in drift time. For example, I got one email saying NTP Skew was 23seconds, then 2 seconds later another email saying that NTP Skew was 0seconds.
    I was wondering if there's some sort of expression similar to .nodata() in the sense that only messages should be sent if the status hasn't changed for X amount of time. For example, only send messages about NTP Skew iif the situation hasn't gotten better for 2 minutes, instead of every time there is a change.
    Thanks.
  • jan.garaj
    • Jan 2010
    • 506
    Zabbix trigger expressions provide an incredibly flexible way of defining problem conditions. If you can express your problem using plain English or any other human language, there is a great chance it could be represented using triggers. I’ve noticed that even experienced Zabbix users are not always aware of the true power of triggers. The […]
    Functions: min, max, avg, ...:
