I spun up an Amazon instance with Zabbix AMI powered by Abookaa found in the Amazon Marketplace. I have tried working with their support but after their attempts at resolving this issue they seem to have given up and I haven't heard back from them since.
My issue is that after following their setup instructions. I feel like a step may be missing from their instructions somewhere.
http://abookaa.com/zabbix-how-to/ < instructions here
I'm at the last step where the instances won't show up
If I check the items enabled it says Monitoring EC2 Instances is Not Supported
Any ideas? Thanks!
Any ideas? Thanks!
