Monitoring a switch
  • dhull
    • Aug 2014
    • 13
    Monitoring a switch
    I'm running Zabbix 2.2.6 on Ubuntu 14.04.
    I'm monitoring a switch with template SNMP Network Device Interfaces. It works but I'm getting notifications every time a port changes state, up down.
    Is there a way to turn off triggers for a host or prevent Zabbix from sending an email for this host?
    There are 385 triggers and I don't see a way to disable them all at once.
    Thanks!
  • BDiE8VNy
    • Apr 2010
    • 680
    Yes. See Zabbix actions
    Btw, you can indeed disable many triggers in one run. See the combo-box at the bottom of Configuration->Templates/Hosts->Triggers.
    Although for LLD created triggers this is not supported yet. See ZBXNEXT-821.
    • dhull
      • Aug 2014
      • 13
      Action
      Thanks for the info. I created a device group for devices that don't require notifications. Added that to an action with <>. That should do the trick.
      I looked for your other suggestion. The drop down menu for the triggers is grayed out and you can't use the check box next to the trigger.
      I still would like to disable most of the triggers. That would keep the dashboard free from switch port issues.
      • dhull
        • Aug 2014
        • 13
        I figured out how to disable the triggers.
        1. Disable the triggers in the discovery portion of the template
        2. Add a host and us the template.
        The triggers are added to the new host but they are disabled.
