Access denied for user 'zabbix'@'localhost' (using password: YES)
  • vitS
    • Apr 2021
    • 43
    I created UserParameter in zabbix_agent.conf mysql.query[*] (echo "query" mysql -N -u zabbix -p pass)
    In /usr/local/etc/zabbix Created .mycnf:
    [client]
    user = zabbix
    password = pass
    User zabbix created with all priveleges
    If to check mysql -u zabbix -p
    I can login, and select
    But from Test on Item ( In Item I put mysql.query Is it correct? )
    Server we have 5.0.3, but I found that client is on version 4.4.4 ( Can it be the problem? )
    Thanks,
  • tomeksup
    • Apr 2021
    • 14
    Are you use sudo ?
    • vitS
      • Apr 2021
      • 43
      Hi what do You mean use sudo?
      Just checked: Entered to server, where zabbix agen placed -
      sudo su and tried mysql -u zabbix -p
      Working fine
      Ctrl + D (logout)
      mysql -u zabbix -p
      The same results - everything fine, but fro zabbix GUI still access denied
      Thanks,
      • tomeksup
        • Apr 2021
        • 14
        Have you add correct permission to database for user used in GUI ?
        • vitS
          • Apr 2021
          • 43
          What do You mean correct permissions?
          Do You mean Grants to zabbix user?
          Due to my error - I have such Grants
          | Grants for zabbix@localhost |
          | GRANT PROCESS, SHOW DATABASES, REPLICATION CLIENT, SHOW VIEW ON *.* TO 'zabbix'@'localhost' |
          | GRANT SELECT ON `sys`.* TO 'zabbix'@'localhost' |
          | GRANT SELECT ON `performance_schema`.* TO 'zabbix'@'localhost' |
          | GRANT SELECT ON `piearsta_web`.* TO 'zabbix'@'localhost' |
          Also i created user zabbix@% and I have such grants there
          | Grants for zabbix@% |
          | GRANT PROCESS, SHOW DATABASES, REPLICATION CLIENT, SHOW VIEW ON *.* TO 'zabbix'@'%' |
          | GRANT SELECT ON `performance_schema`.* TO 'zabbix'@'%' |
          | GRANT SELECT ON `piearsta_web`.* TO 'zabbix'@'%' |
          FLUSH PRIVILEGES; //were executed
          What permissions from GUI can be more?
          Thanks,
          • tomeksup
            • Apr 2021
            • 14
            I used 'zabbix'@'localhost' |
            • vitS
              • Apr 2021
              • 43
              What do You mean You used?
              Where should I declare it? I mean like zabix@localhost.
              What I did: I put on agentd.conf In Userparameter: ....mysql -N -u zabbix -p pass)
              I didn't use localhost just zabbix and created 2 users zabbix@localhost and zabbix@% ?
              Zabbix decided by it is own zabbix@localhost. If I correctly understood zabbix through port 10050 - go to agent (on other server) and on on other server by zabbix@localhost connects to DB.
              Thanks,
              • vitS
                • Apr 2021
                • 43
                Ok, I found the issue:
                In UserParameter on agent I wrote: mysql.query[*] (echo "query" mysql -N -u zabbix -p pass)
                Which is not correct - should be:
                mysql.query[*] (echo "query" mysql -N -uzabbix -ppass)
                Thank You,
                • thierry
                  • Nov 2017
                  • 41
                  hi,
                  could you explain please?
                  we don't see what is code, comment, parameters ....
