Help with Hysteresis
  • akbar415
    • May 2015
    • 119
    Hello.
    I have a lot of web scenarios in zabbix and they are annoying me with triggers.
    So, I decided configure the triggers with hysteresis. But now I have false positives.
    This is the way I configured the triggers
    ({TRIGGER.VALUE}=0 and
    {frontend01:web.test.fail[InitialPage].sum(3m)}>1)
    or
    ({TRIGGER.VALUE}=1 and
    {frontend01:web.test.fail[InitialPage].sum(4m)}=0)
    Someone can help me please.
  • akbar415
    • May 2015
    • 119
    This is drive me nuts.
    I already tried this two ways with no success
    {srvwww:web.test.fail[InitialPage].sum(5m)}>1)
    or
    {srvwww:web.test.fail[InitialPage].sum(4m)}=0)
    and
    {srvwww:web.test.fail[InitialPage].last(#1)}=1 and
    {srvwww:web.test.fail[InitialPage].last(#2)}=1 and
    {srvwww:web.test.fail[InitialPage].last(#3)}=1)
    or
    {srvwww:web.test.fail[InitialPage].last(#1)}=0 and
    {srvwww:web.test.fail[InitialPage].last(#2)}=0 and
    {srvwww:web.test.fail[InitialPage].last(#3)}=0)
    None of this worked. The trigger keep flapping between status every 30s.
    Anybody can help me.
    Sorry for the bad englsih.
    • ArtemK
      • May 2013
      • 232
      second condition defines rule for trigger to stay in problem state, i.e. don't switch to OK, until web page is available at least 5 minutes:
      or
      {srvwww:web.test.fail[InitialPage].max(5m)}#0)
      * "#" symbol was replaced in 2.4, I don't remebmer is it "<>" now or what, check docs.
      max(5m)}#0 defines, that this trigger remains in problem state, until all values for web.test.fail key are 0 (web check is performed successfully) for 5 minutes.
      • akbar415
        • May 2015
        • 119
        or
        Thanks ArtemK.
        My trigger don't works because I got it wrong. I thought the expression was "the situation that will take out the alarm", no that the trigger will remains until ...
        thanks.
        • ArtemK
          • May 2013
          • 232
          you are welcome! Alexei explained hysteresis quite well in this blog post (check comments also)
