Web scenario URL fails when different port is specified
  • froner
    • Jul 2015
    When I specify a port in the URL for a step in the web scenario,
    for example http://testLB:8888
    the test fails and the log states:
    12116:20150722:185944.532 cannot process step "testWeb" of web scenario "testWeb" on host "TestIT": Couldn't connect to server
    In this case, network trace shows that zabbix does not make any connection attempt with the remote server.
    On the other hand, http://testLB works.
    Both URLs can be fetched with wget fromm the zabbix server.
    I only get the web scenario to work when I do not specify a different port than 80. Anyone else who experiences this?
  • fbasurte
    • Jul 2013
    • 10
    I have the same issue
    did you get to solve it?
    I am now in zabbix 3.0.2
    Thanks in advance
    kiko.-
    • LxP
      • Jun 2016
      Same issue in 2.4.8 and 3.0.2 version, but in 2.4.6 it's ok
      this is a bug or there is another way to do it.
      • fbasurte
        • Jul 2013
        • 10
        In my case it was the firewall and selinux. After that it worked fine
        • aaanju.of
          • Aug 2016
          For me, its same.
          not working for zabbix 3.
          i can successfully curl the given url
          ex: curl http://www.abc.com:8080
          but following error is given in zabbix
          Step "app1" [1 of 1] failed: Couldn't connect to server: Failed to connect to 10.10.10.10: Permission denied
          is there a way to use custom template for web scenario for non standard ports
          • marco.mandricardo
            • Jul 2022
            same problem here,
            i have zabbix 6.0
            if i do a web scenario with 1 step to check availability with only require response code 200,
            i get the same error of aaanju.of
            some news after long time?
