GPS Coordinates regular expressions
  • markfree
    • Apr 2019
    • 875
    I'm getting some simple GPS coordinates from a script that output something like this:
    -75.93367886,-126.94287288
    To read that I created an item that reads the script output. Below it, there are 2 dependant items, one for latitude and another for longitude.
    For each dependant item, I thought of pre-processing that raw value using some regular expressions, but I just can't figure out how to do it.
    Any tips?
  • atousled
    • Mar 2021
    Helo, (-\d+\.\d+) for lat and (?<=,\ )(-\d+\.\d+) for lon. gl
    • markfree
      • Apr 2019
      • 875
      That works great.
      Just as expected.
      Thanks a lot.
        • 4985
        It is as it is said on a page you followed
        [quote=atousled]Helo, (-\d+\.\d+) for lat and (?This will work only for coordinates starting with "-"..
        Both dependant items can use same regex "(.*),(.*)" and one uses \1 for output and other \2
        • brantpeter
          • Oct 2023
          You can use regular expressions like this for latitude and longitude extraction: Latitude: (-?\d+\.\d+), Longitude: (-?\d+\.\d+).
